Should I cut off and wire directly to amp terminal or will there be no differenct if plugged into the cig outlet. Battery and amp is in the trunk. Have a magnum so not battery in front. Have a d3100 back there and a mechman 320amp alt running a saz-3500v2.
Anyone actually done it both ways and notice different readings?
05 dodge magnum rt
DEH-80PRS
Rockford fosgate T600.4
st200 tweeters
Sundown Neo Pro 6.5 v2's
2 Saz-3500v2- Toolmaker dual 1/0 inputs
2 Sundown ZV4 12" D1
1/0 Sky High Power wire OFC
3 XS D3100- Toolmaker battery terminals
Mechman 320 Amp Alt
Smd Voltmeter
KnuKoncept 1/0 OFC
Amp inputs will read different
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
