Rocktown SPL Posted June 29, 2014 Report Posted June 29, 2014 Check this facility out at NASA Goddard: And this one, The RATF at the Space Power Facility at NASA's Plum Brook Station in Sandusky, Ohio: Arkansas Based Car Audio Bass Music & Test/Competition Producer Now Streaming worldwide on: Spotify
Rocktown SPL Posted June 29, 2014 Author Report Posted June 29, 2014 "The RATF chamber is located within the Vibroacoustic Highbay, taking advantage of the 1.8 m (6 ft) thick surrounding concrete walls to help attenuate sound migration through the SPF. The highbay also serves as redundant protection from the RATF nitrogen atmosphere during operation. The RATF is a 2,860 m3 (101,189 ft3) reverberant acoustic chamber capable of achieving an empty-chamber acoustic overall sound pressure level (OASPL) of 163 dB. The facility structure is designed for a future upgrade to 166 dB OASPL, including areas in the horn room wall which have been left blank for future installation of additional modulators/horns. The RATF includes various supporting sub-systems including gaseous nitrogen generation system, horn room with acoustic modulators and horns, acoustic control system, and hydraulic supply system. Test articles are mounted onto elevated customer-provided mounting fixtures for testing. The chamber has been constructed with load-bearing wall attachments for future installation of a 5-ton interior bridge crane. The chamber can be operated as a Class 100,000 clean room once the access doors are closed and the facility is cleaned. The combinations of servo-hydraulic and electro-pneumatic noise modulators utilize gaseous nitrogen capable of producing a tailored wide-range of acoustic spectrums in the frequency range from 25 to 10,000 Hz. The RATF chamber internal dimensions are 11.4 m (37.5 ft) wide by 14.5 m (47.5 ft) deep by 17.4 m (57 ft) high." Arkansas Based Car Audio Bass Music & Test/Competition Producer Now Streaming worldwide on: Spotify
