load350z Posted July 1, 2014 Report Posted July 1, 2014 Hey members, looking for suggestions on super tweeters to cap off my system. I'll be running eight 8inch subs ported on 4k, ten 6.5inch speakers (two 6.5s each door) and a pair in the back deck power by a 6.4 incriminator amp. Never used or heard super tweeters before so I just wanted to see what you guys recommend and how many should I get, what impedance. And should I buy a separate amp to run the tweeters on? Thanks 2002 Nissan Altima v6 3.5 Four Incriminator Audio Death Penalty 15s 5 Pairs DS18 Pro Audio X6.5BM 3 Pairs DS18 Super Tweeters Taramps TS2000x4 (Mids Amp) Incriminator Audio 6.4 (Tweeter Amp) Incriminator Audio 40.1 subs amp Rockford Fosgate 3sixty.3 3 shuriken batteries (BT-80 under the hood) (2 BT-120 in the trunk) with isolator Big 3 zero gauge. Excessive amperage H/O 225a Alpine head unit Lots of stinger deadener
Kevin M Posted July 1, 2014 Report Posted July 1, 2014 One pair on 50 watts will get stupid loud. Like louder than you can stand. Budget? Location? Almost all of them run at 8 ohms unless you have more than one wired together. They tend to need eq too; to smooth out the response. You mentioned locations for 6 of the mids. Where are the last 4 going to go? Just curious. 2005 Ford Focus zx4 AMT's and Planars 18" Infinite baffle
Popwarhomie Posted July 1, 2014 Report Posted July 1, 2014 Planning on running active? What mids are you going to use? 2010 Focus coupe- 8 12" wall. 157.5@46hz 2016 Focus ST - SQ build.
load350z Posted July 1, 2014 Author Report Posted July 1, 2014 Thanks for the replies. I'm using cdt's in the stock location already but since i have extra cdt speakers laying around i figured i'll just use them all and build custom door panels to house everything. Basically a pair of cdts 6.5s with super tweeter in the driver and passenger doors. Rear doors will have a pair of 6.5's no tweeter. And the back deck just a pair of 6.5s. Budget! not really worried about budget I seen the super tweeter are in the range of $50-$100each for good ones. 2002 Nissan Altima v6 3.5 Four Incriminator Audio Death Penalty 15s 5 Pairs DS18 Pro Audio X6.5BM 3 Pairs DS18 Super Tweeters Taramps TS2000x4 (Mids Amp) Incriminator Audio 6.4 (Tweeter Amp) Incriminator Audio 40.1 subs amp Rockford Fosgate 3sixty.3 3 shuriken batteries (BT-80 under the hood) (2 BT-120 in the trunk) with isolator Big 3 zero gauge. Excessive amperage H/O 225a Alpine head unit Lots of stinger deadener
