Could make i floating amp rack and mount to the deck led
What I did was mount the amp on the back of the box. Put some digital designs deadening on the box, a sheet of foam on top of that, 3/4" MDF board on top of that foam. Then some more deadener under the feet lol. Worked well.
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
If need be, add like 1/2" wood on top, rubber washers/spacers, then mount amp. I did this before and vibration was reduced A LOT. Cheap and well worth it.
I did this as well. Also added 2 small strips of weather stripping foam under amp
I don't fuck around. I go from zero to I hope you die in less than 2 posts
build log http://www.stevemeadedesigns.com/board/topic/104524-new-subs-coming-sundown-3500d-arc-audio-cable-lacing-crescendo/
