rf components ideal amp
flexinfusion
I have a set of rf t1675 components and im wondering what would be the ideal budget amo to run them. And how would I wire the amo to the components. Ive never messed with mids and highs off a amp just subs.
2009 fusion
Steeda Mods kenwood DDX418
RF T1675-s Front doors
RF T165 Rear doors
OLD SETUP:
ab XFL 1222Audiopipe 1500d
2.5cu ft 32hz
These are the Power 6.75" comps? They are rated for 100w rms per side, and with those speakers I don't know that I would skimp. I'm not very experienced with many brands but I can't imagine a RF would be bad, especially if you got a Punch or Power series.
As for wires I've always just bought kits, they will have everything you need. But it's the same as wiring for a sub amp, just with more speaker wire.
The wiring part I am cunfused about is wiring the tweeters and mids to the amp. Would a 2 or 4 channel work for the front and rear doors.
2009 fusion
RF T165 Rear doors
OLD SETUP:
2.5cu ft 32hz
That really depends. If you are using the passive crossovers you only need two channels per pair of speakers (you run one crossover per channel, and one mid and one tweeter per crossover.) If you are running them active you will need one channel per mid and one channel per tweeter, which would be two channels per pair of speakers. This is of course assuming you are talking about the Power series components.
Whats passive crossover. And yes I have the power series.
2009 fusion
RF T165 Rear doors
OLD SETUP:
2.5cu ft 32hz
I took "What passive crossover?" to mean that there was no separate X-over with the speakers.
@ OP Come on man! Don't leave out the details. ;)
2011 Chevy Silverado LT 5.3L 4x4 Ext.-cab
"Enjoy yourself. It's later than you think."
Sorry for the left out details but yes I have a seperate crossover and seperate mid driver and tweeter.
2009 fusion
RF T165 Rear doors
OLD SETUP:
2.5cu ft 32hz
Alrighty, then yeah one channel per crossover like I said. Good luck!
  • Who's Online   0 Members, 0 Anonymous, 835 Guests (See full list)
