g2shuck Posted August 6, 2014 Report Share Posted August 6, 2014 Do these look like good specs for a car audio Oscope/dmm? 100kHz graphical storage oscilloscope and true RMS multimeter with RS232. Oscilloscope graphical functions: Single channel, volts/division (150mV to 800V), 500ns glitch capture, pre/post-trigger (-4div./+10div.). Oscilloscope bandwidth: DC to 100kHz with a sample rate of 1 million samples/sec. Oscilloscope display: 128 x 64 pixel graphic LCD (view area: 2.8x1.5"). Multimeter display: 3-3/4 digit (4000 count) LCD with Bargraph and datahold. Built-in RS-232 PC interface. Multimeter functions: AC/DC voltage/current, resistance, capacitance, frequency, dB, temperature (using adapter), duty cycle, pulse width, period, TTL level generator, diode and continuity tests. Record/recall Min/Max/Average with time stamping. Generator output provides 10Hz to 20kHz TLL level output. Store and recall 15 waveforms plus setup. Graphical HELP screens explains functions. Over-range indication and Auto power off. Surge protection to 6kV. IEC1010-1 1000V CAT II, CE, UL liste The part that I really need to know about is this part Oscilloscope bandwidth: DC to 100kHz with a sample rate of 1 million samples/sec. I know amplifiers output ac voltage but this says dc. Will it not work for ac? 2000 Toyota Camry With Sealed Off Trunk Sky High OFC Wiring DC Power 270 XP Alt AQ 2200 Sub Amp Two DC Level 4 m2 12s 80 Mil Murdetmat Gathering Parts For Wall Build. Team DC Audio 2014 Member Link to comment Share on other sites More sharing options...
