4th order help, want to double my design.
scooter99
So I recently got a design for a 4th order blow through for 2 15's.
Since that has happened some other decisions have been made and the truck I'm going to put these in, has been officially labeled as my "Hobby/Project" truck. So I can do whatever I want with it.
Now, I'd like to double it and go 4 15's.
My question is, do I need a whole new design spec wise, or can I double the air space, sealed and ported, I have in the current design?
Also what about the port? Does the port double or does it need a new port design?
Thanks for any help.
Are you doubling power as well? If each sub is still getting the same power then yes, double everything. Airspace as well as port area. Your port depth can stay the same.
If you are going with less power you may want to consider a new design
Team NorthWestSPL
If its ever the plan in the future I would just build for that. Its not like it wont work on less power. There is a just a chance that you could redesign for less power and get more efficiency.
Team NorthWestSPL
I may just do it now too, if I can get the money together. Ok so if I'm planning to be on the same power doubling, then simply doubling the design specs will be fine. And if I understand you correctly, Port is the same thing. Double it as well, but leave the length the same.
  • Who's Online   1 Member, 0 Anonymous, 3256 Guests (See full list)
