blacksheep Posted August 16, 2014 Report Posted August 16, 2014 hello all, noob here witth a few qustions. i want to finally make the leap to the next level sub. i have run audiobahn 1206t's for nearly a decade because i dont see anything in its class that will outperform it (18mm xmax 1way in gap, 92db spl @ 1w with 1100w rms rating and pretty nice sq for a cheap sub)... so its time to upgrade... i have a visonik 4kw amp but only get 3kw or so cuz im on 12v still. i also have a blown audiobahn immortal 15" with crappy flamer bskt but has a nice motor... so my question is what basket may fit so that i may have psi put a frankenwoofer together? could i convert it to a 3kw 18" with a re or dd basket? any suggestions other than spend $1000+ on a new woofer?
gally Posted August 16, 2014 Report Posted August 16, 2014 for less than 1000 you can get plenty of way better subs than you had it till now....look at the sundown X or ZV4 series...there are pretty nice... if you want more maybe a Fi SP4? there are plenty of options and you dont necessarly have to build a franken woofer.... 2010 Chevrolet Cruze Radio --- pioneer mvh-200vbt Front/back --- alpine type s 6.5" Sub Control --- Pac LC1 Sub Amp --- GZPA 1.4K Sub --- GZNW 15XSPL D1 Battery - GZBP 12.2500X
