my first big build 3 15 sp4s on ampere 8.0 TFE 4th order blow through 06 avalanche
Dual alternators ftw. I had the same problem with my kit, belt was too short. So short that it was smoking on the alternator pulleys when I first started up, but I didn't get a new belt, there are three different positions for the idler pulley on the bracket, so I moved the pulley down to the lowest spot and it did the trick.
Anyway, pod look good man.
thanks,ill have to check my bracket for more positions.
Looks like its cutting bit close with gap between pod and dash..looks good though..
thanks! its a little snug,but there is space,just hard to take an accurate picture.DC0688F8-0775-4A6F-89EE-351F544CED7D_zps
second pod turned out better than first one. i pulled the fleece much tighter than the first one, and i only had to put matt on the inside,after 2 coats of sun flash on the outside.563DB33C-949D-4432-90DF-6E33C7511706_zps
everything is good except one little spot. i should have put the pods in the door panel when i put the resin on, but i tried to get away with it.2BDB23E4-DB2B-4736-85B9-2C1D8ACB9A51_zps
thanks, i got the smaller belt on. It ended up being a total inch and a half smaller than the one that came in the kit. Voltage is much better now.A8114B1F-9F3F-4F61-A252-031C32977E55_zps
after several hours of heating and stretching,i finally got one done.its still not perfect,but I'm happy.D1A6DCC3-DD58-43CD-96FD-BF560B7CEC46_zps
