Wiring some mids & High up to an Amp
zZZzzzSnooze
The tweet has it’s own hi-pass filter. The woofer can be run full-range or you could lo-pass the signal with a passive X-over. If you are using a 4-channel amp you could lo-pass the signal to the woofers with the amp’s built in X-over. In this case the tweet’s X-over wouldn’t be needed if you wanted to go with an all active X-over setup.
The woofer will be a 4Ω load at it’s range of frequencies and the tweet will present a 4Ω load to the high frequencies. Together they are form a nominal 4Ω load to the amplifier.
2011 Chevy Silverado LT 5.3L 4x4 Ext.-cab
"Enjoy yourself. It's later than you think."
  • Who's Online   1 Member, 0 Anonymous, 1454 Guests (See full list)
