Ahmed Johnson Posted September 12, 2014 Report Share Posted September 12, 2014 Just so you know dont turn the LOC up high, that shit is clip city. I was using one for a while after my HU was stolen and my subs was heating up fast. Link to comment Share on other sites More sharing options...
MatthewBigBossWilliams Posted September 13, 2014 Author Report Share Posted September 13, 2014 Well it worked with the other amp perfectly fine. it sucks because idk why the amp wont produce sound. I checked continuity everywhere and it doesnt reproduce. I checked and I think it could be the RCA. Link to comment Share on other sites More sharing options...
REH Posted September 13, 2014 Report Share Posted September 13, 2014 Well it worked with the other amp perfectly fine. it sucks because idk why the amp wont produce sound. I checked continuity everywhere and it doesnt reproduce. I checked and I think it could be the RCA. If you used the exact same wires everywhere, and the old amp just worked when you swapped it out then it's not your RCA cables. It's definitely something with your amp at that point, check all the settings on the amp. Link to comment Share on other sites More sharing options...
MatthewBigBossWilliams Posted September 13, 2014 Author Report Share Posted September 13, 2014 The only thing i adjusted was was the volume. take a look at this on amazon because it has pictures that i cant upload. http://www.amazon.com/gp/product/B004HJ1WV6/ref=s9_psimh_gw_p422_d0_i1?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=013596BF3PR9XRPY92BF&pf_rd_t=101&pf_rd_p=1688200382&pf_rd_i=507846 The input gain is the only thing i touched. it isnt in slave it is in master. Link to comment Share on other sites More sharing options...
REH Posted September 13, 2014 Report Share Posted September 13, 2014 The only thing i adjusted was was the volume. take a look at this on amazon because it has pictures that i cant upload. http://www.amazon.com/gp/product/B004HJ1WV6/ref=s9_psimh_gw_p422_d0_i1?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=013596BF3PR9XRPY92BF&pf_rd_t=101&pf_rd_p=1688200382&pf_rd_i=507846 The input gain is the only thing i touched. it isnt in slave it is in master. Where do you have a slave/master switch? Because I'm not seeing it on that amp. Do you have your filters set correctly? Sure you have your RCA plugged into the input and not the output? You're getting absolutely zero sound out of the amp at all? Link to comment Share on other sites More sharing options...
MatthewBigBossWilliams Posted September 13, 2014 Author Report Share Posted September 13, 2014 ill get it off of sonic. one sec. Link to comment Share on other sites More sharing options...
MatthewBigBossWilliams Posted September 13, 2014 Author Report Share Posted September 13, 2014 The only thing i adjusted was was the volume. take a look at this on amazon because it has pictures that i cant upload. http://www.amazon.com/gp/product/B004HJ1WV6/ref=s9_psimh_gw_p422_d0_i1?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=013596BF3PR9XRPY92BF&pf_rd_t=101&pf_rd_p=1688200382&pf_rd_i=507846 The input gain is the only thing i touched. it isnt in slave it is in master. Where do you have a slave/master switch? Because I'm not seeing it on that amp. Do you have your filters set correctly? Sure you have your RCA plugged into the input and not the output? You're getting absolutely zero sound out of the amp at all? http://www.sonicelectronix.com/item_44049_Lanzar-OPTI7001D.html Thats the right amp. Link to comment Share on other sites More sharing options...
REH Posted September 13, 2014 Report Share Posted September 13, 2014 The only thing i adjusted was was the volume. take a look at this on amazon because it has pictures that i cant upload. http://www.amazon.com/gp/product/B004HJ1WV6/ref=s9_psimh_gw_p422_d0_i1?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=013596BF3PR9XRPY92BF&pf_rd_t=101&pf_rd_p=1688200382&pf_rd_i=507846 The input gain is the only thing i touched. it isnt in slave it is in master. Where do you have a slave/master switch? Because I'm not seeing it on that amp. Do you have your filters set correctly? Sure you have your RCA plugged into the input and not the output? You're getting absolutely zero sound out of the amp at all? http://www.sonicelectronix.com/item_44049_Lanzar-OPTI7001D.html Thats the right amp. Got ya, same questions still from the last post though. - except the switch Link to comment Share on other sites More sharing options...
MatthewBigBossWilliams Posted September 13, 2014 Author Report Share Posted September 13, 2014 I tried plugging the RCA into both input and output and had nothing. and the filters they are all set down. are they not supposed to be? Link to comment Share on other sites More sharing options...
MatthewBigBossWilliams Posted September 14, 2014 Author Report Share Posted September 14, 2014 Anyone else have any suggestions? Link to comment Share on other sites More sharing options...
