biscuitownz Posted September 15, 2014 Report Posted September 15, 2014 Hi all, I recently just ordered a fi ssd 10" and I'm trying to plan out the box. I have a 350z and I'm trying to figure out which way to place the ports/subs. I started off with a rockford 10" in a L port, subs/port firing forward. I didn't like the rockford sub too much so I bought 2 dayton audio 8s and built a 4th order for them, port firing to the back. The dayton's sound good and do hit pretty low but I wanted it to be a bit louder. Anyway, I've decided that my options are limited to another L port or I can do aero ports (I'm leaning towards aero). At the moment, I'm thinking sub back and ports forward with the aero. If I do L port I'll probably just end up doing sub/port forward again. Basically I just wanted to get your thoughts on where I should fire my ports. Thanks all Edit; also what would be the optimal port area for the ssd? I calculated with the L port that it would be around 18in^2 in a 1.8ft^3 box. With the aero ports (2 3") I would have around 14in^2. Each port setup will be tuned around 35-38hz.
