Need 2 - SA-8s for 01 Trans Am.. Questions and enclosure options
Got all the pieces cut for the box above this post. Only thing of concern is the depth of the sub... the depth of the box is only 7 inches. The mounting depth of the sub is 6 5/8... which only leaves about 1/2 between the back of the box and the magnet.. is that OK, or should I add a second baffle to raise it up another 3/4"?
  • 1 month later...
sub is amazing, I cant help but to add another.... amp seems to be holding voltage around 14, which puts be at a descent power setup... 2 sa-8s @ 1000 rms off a aq1200d .. This sub is noting less than amazing , and even tho I'm behind the times seeing as the v3 is on its way out.. I just want to thank Sundown for all the amazing mini subs over the years!
  • Who's Online   0 Members, 0 Anonymous, 382 Guests (See full list)
