Alt Problems For 02 Dodge Ram
im running into a problem finding an alt or 2 for my 02 dodge ram it has the 4.7 .. the problems that i am running into are... the way it mounts and "ears" of my alt and the size restrictions of it .. they only can produce @ 160 amp alt... but im currently running 1 re xxx15 (new one)(in a custom ported armrest) with 2 pb asa 1000.1 strapped at 1 ohm ( not at the recommended 2 ohm) i have 2 redtops under the hood 2 kinetik 2400s in the tool box and 2 kinetik 600 1 at each 1000.1 im also runnung 2 asa 600.4 for the highs... driving around town volts stay aroung 11.5 but if i stop volts go as low as 9.3.... the major prob. is i just recieved (finally ,but worth the wait) my 4 btl 18s and my camper shell will be here soon. and if i cant power the system i have now what the heck am i going to do in a few weeks.... oh yeah the big 3 thing is done it helped out alot... i have emailed and called everyone i know ( iraggi has not responded yet) but i need some suggestions...please help
****11.5 and 9.3 volts are with system up to full volume****
02 dodge ram quad cab 4.7
pioneer 9800bt
pioneer 5700 dvd(yes 2 headunits 5700 for dvd only)
1 re xxx 15 (new style in center console)
4 18" fi btls in snugtop
12 mb quart 6.5s original ones not maxxsonics (kicks, 3 in each front door 2 in each back door)
quart 4" dash sp
2 soundstream xxx6500s
1 pd asa1000.1 for the xxx15
4 pb asa600.4 highs
4 7" screens
1 15" flipdown
2 red tops
16 g31 yellow tops
playstation 2
4 8x11 p.a. horns under truck (music plays through them)
db 80.2 for horns
2 underglow kits (1 flex kit in fenderwells)
24" martin bros vampires
you might have the wireing on the batterys wrong ??? and just take a DMM and test the alt when running and find out what you get there and if you get more then what you are saying them you know to start from there and check the wires
with the truck off all the batts say between 12.7 and 12.9 with the truck running( idle) they all say between 13.4 and 13.8 and when i rev it up @ 2000rpm they read 14.1 -14.4 there is double alt wire from alt to 2 red tops( under hood) those also have double alt engine and body grounds then double alt power running from red tops to 2 kenetik 2400s in the tool box they also have double alt frame and body grounds from there 2 single alt wires into the cab ,each 2 a kenetik 600 and about a 8 inch peice of 4 awg into each amps all fused between each other of course ( fuses are good)
pioneer 9800bt
quart 4" dash sp
4 pb asa600.4 highs
4 7" screens
1 15" flipdown
2 red tops
16 g31 yellow tops
playstation 2
db 80.2 for horns
huh beats me
test the alt tho and see what it says and where do you got your volt meter hooked up to in the cab??
huh beats me
volt meter is hooked to a + on one 1000 and - on the other 1000
at the alternator volts are same or slightly ( like .1or.3) higher than batts
the alternator says its 160 amps ( according to the paper) but it does not say at what rpm
pioneer 9800bt
quart 4" dash sp
4 pb asa600.4 highs
4 7" screens
1 15" flipdown
2 red tops
16 g31 yellow tops
playstation 2
db 80.2 for horns
i do not know but are you going by the volt meter when driveing down the road??? if so my try putting the pos and neg into 1 amp and put the blue wire onto the remote wire in the amp and see if that tells you different
it will not have anything to do with chargeing but if you are looking at that and it is saying 11 something that might be b/c you got the power on one and and ground on another just run it together??
Sounds normal to me. The factory alt is rated at 136A, so if you got a 160A you didn't gain much over stock......Im not sure of your total draw of you audio but you should look for an alt rated at least 250A.
  • Who's Online   0 Members, 0 Anonymous, 4662 Guests (See full list)
