Audio Display Board Switch LED's
I'm putting our audio display together for our shop and have run into an issue with the new switches we had to order. This is a second-hand Audio Authority system where we did not receive all of the original switches. Now, the original switches had smaller LED's for illumination. These are two-wire switches. The voltage coming form the boards is 4.5-5VDC when the switch is closed.
Now, the newer switches are cosmetically identical, except the bulbs being used look like 197 bulbs, and are 12VDC bulbs. I do not have a lot of knowledge on automotive bulbs or LED's. What I am looking for, or hope that exists is a white bulb that would plug directly into this slot and illuminate with 4-6VDC.
I assume I will need to go the LED route, but still have no idea where to go. I have been searching Google for a bit to no avail.
The older switches are the two pictured on the left. The new switch style is on the right.
On 6/30/2011 at 1:11 AM, 'Ray' said:
Acoustical energy is free. Electrical energy is not.
i bet the 194 LED would work. At 5v they might not be as bright but LED's seem to be very forgiving when working at different voltage. I would try some of these maybe?
https://www.superbrightleds.com/moreinfo/miniature-wedge-base/194-led-bulb-1-led-wedge-base/197/
New build coming........
YouTube:http://www.youtube.c...6?feature=guide
Old Build Log: http://www.stevemead...d-on-the-cheap/
Old Screen name: Redrebel66
