RatBass1998 Posted March 31, 2008 Report Posted March 31, 2008 i was thinking like 16-20 at 28 hz, i could run em nicely on my 200.1 at 3k at 1 ohm or like 3.5-3.6k at .5 it would be a wall in a wagon in the back behind the back row seats i read they can handle upwards of 1.8k rms music so i should be safe im not ditching the Ultra im thinking of doing a blow through with the Ultra in my standard cab S10 any thoughts? how would the output be with low tuning? #'s dont matter but think with like a 40 hz port the 50's would be possible on tones? 15" LMS Ultra AB VFL 200.1 3kw+ rms@ 1 ohm <-- 500.1 in near furture 3.5 cubes at 34 hertz 2 Exide Orbital's 200 Amp EA Alt 125 sq ft BXT
spl explorer Posted March 31, 2008 Report Posted March 31, 2008 That would be a sick setup 4 sure! Loved my Qs wile I had them. As for 16-20 cubes… I don’t think I would go that big. I had my single Q in an 8.8 cube box after displacement and tuned @ 32Hz and mayne did it work the suspension in on that Q. Sounded GREAT though! Pulled a 146dB all day on music witch wasn’t bad for a single Q. I would look at building a box some ware around 12-16 cubes if you want a BIG box. The bigger the box the less power it will take to get the subs going. So I don’t see those Qs lasting to long in a 16-20 cube box on 3K watts but that’s up to you. As for it handling 1.8K RMS watts. I slammed my single Q on 2K RMS for about 3 months before I got a second woofer. They will take it but make sure the amp is set correctly. Also I loved how my Qs sounded between 30-32Hz. Hit the lows like crazy wile still picking up the highs. Build log with pix when you start on the build plz. Good luck bro! Rollerz Only - Sacramento Chapter. 6 Time Lowrider Magazine club of the year 94 Xploder on 22s - Gutted for now... 87 Cadillac Fleetwood Brougham on hydros, fully euroed out Tookie blue *ROLLERZ ONLY MAFIA* Crankin the volume knob and hittin switches. http://www.rollerzonly.com
