Masterbasser Posted November 28, 2014 Report Posted November 28, 2014 I dont have any batteries for my build yet i am ordering the terminals and wiring this weekend I was looking at some northstar batteries it appears they have top post style connections (g31s) 1 , Is there any difference performance wise to using bolt down or clamp style battery terminals? would think maybe top post is better more connection area 2, also if I want to use bolt down terminals (they seem to be cheaper then clamp style) do i need anything else? 3, does the top post just twist off and you can use a bolt to bolt them down? waiting to order until i hear input from you guys, LMK pls Kenwood excelon ddx795 3 370 amp CES alternators (audio side only) McLaren dome tweeters Crescendo 6.5 ultra neos NVX JAD800.4 4 PA x4 SPL 18's 4 Digital Designs m5's at .7 ohms each 2 K2 80 ah lithiums 3 group 31 agms Ledglow million color (12 piece) 2007 Yukon xl
Masterbasser Posted November 28, 2014 Author Report Posted November 28, 2014 lmk before they run out of stock!! lol Kenwood excelon ddx795 3 370 amp CES alternators (audio side only) McLaren dome tweeters Crescendo 6.5 ultra neos NVX JAD800.4 4 PA x4 SPL 18's 4 Digital Designs m5's at .7 ohms each 2 K2 80 ah lithiums 3 group 31 agms Ledglow million color (12 piece) 2007 Yukon xl
Jessica Posted November 28, 2014 Report Posted November 28, 2014 just run whatever works for you. I'm using regular AGM's with posts on top and using the military style battery terminals. if you are replacing the front battery and it has side post terminals try to buy something that has bolt down so it will be easier to re-wire stock electrical to it. otherwise its just preference. For most people regular ol top post work fine, but if you are going to run a large bank in the rear bolt down make it easy to use buss bars. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
Masterbasser Posted November 28, 2014 Author Report Posted November 28, 2014 thanks for the answer i only have room for 2 g31 batterys in the rear of car and they will be on opposite sides of the hatch think i will go with the top clamp post style ones then Kenwood excelon ddx795 3 370 amp CES alternators (audio side only) McLaren dome tweeters Crescendo 6.5 ultra neos NVX JAD800.4 4 PA x4 SPL 18's 4 Digital Designs m5's at .7 ohms each 2 K2 80 ah lithiums 3 group 31 agms Ledglow million color (12 piece) 2007 Yukon xl
