Bolt down or top post clamp style battery terminals? HELP
I dont have any batteries for my build yet
i am ordering the terminals and wiring this weekend
I was looking at some northstar batteries it appears they have top post style connections (g31s)
1 , Is there any difference performance wise to using bolt down or clamp style battery terminals? would think maybe top post is better more connection area
2, also if I want to use bolt down terminals (they seem to be cheaper then clamp style) do i need anything else?
3, does the top post just twist off and you can use a bolt to bolt them down?
waiting to order until i hear input from you guys, LMK pls
Kenwood excelon ddx795
 3 370 amp CES alternators (audio side only)
       McLaren dome tweeters                                   Crescendo 6.5 ultra neos
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
                     4 Digital Designs m5's at .7 ohms each
        2 K2 80 ah lithiums
                              3 group 31 agms                                       Ledglow million color (12 piece)
2007 Yukon xl
lmk before they run out of stock!! lol
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
        2 K2 80 ah lithiums
2007 Yukon xl
just run whatever works for you. I'm using regular AGM's with posts on top and using the military style battery terminals. if you are replacing the front battery and it has side post terminals try to buy something that has bolt down so it will be easier to re-wire stock electrical to it. otherwise its just preference.
For most people regular ol top post work fine, but if you are going to run a large bank in the rear bolt down make it easy to use buss bars.
thanks for the answer i only have room for 2 g31 batterys in the rear of car and they will be on opposite sides of the hatch think i will go with the top clamp post style ones then
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
        2 K2 80 ah lithiums
2007 Yukon xl
  • Who's Online   1 Member, 0 Anonymous, 1292 Guests (See full list)
