I guess I can show off my Rockford Doors.
hell yea should be wicked, gonna need to see vids and pics for sure. curious to what ur plans for electrical are, you will be pullin alot of amps with that huge power!
D6500 under the hood. 4x d3100 in the back. SkyHigh 2/0 Power cable. 1 run neg/poss for the moment might add a second run down the line. Haven't chosen an alt yet. Want a singer 320 amp alt but a friend of mine is trying to sway me to an ohio generator Alt. I think there max is a 280 amp?
~Meh~
check out the mechman 6 phase alts , i was going with ohio generator till i did a ton of research even researching 6 phase generators a bit. and then i went with the mechman 320 amp billet tech hairpin stator 6 phase for my application, certain vehicles he can make like 390 amp alts for pretty sick, id run 2 runs off positive and negative as well
you should be pretty set with a big alternator,go as big as you can on alt
Kenwood excelon ddx795
 3 370 amp CES alternators (audio side only)
       McLaren dome tweeters                                   Crescendo 6.5 ultra neos
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
                     4 Digital Designs m5's at .7 ohms each
        2 K2 80 ah lithiums
                              3 group 31 agms                                       Ledglow million color (12 piece)
2007 Yukon xl
Thanks man! All great ideas. Appreciated.
~Meh~
Get Singer,mechman,or dc alt. that is all.
