Do you guys think i will get a clean system running two rockford fosgate T600-2s for mids/highs?
One amp for mids (4ohm)
and one amp running four, 8 ohm tweeters wired in pararell for 4ohm final. Ofc with passive crossover.
Lots of people tell me to run one amp for mids and highs, but im still not sure..
Its much cheaper to buy two T600s than one T1000.4 amp :)
you don't have to, you Can run channel 1&2 for highs 3&4 for mids.
i just don't know how the time alignment will be.
what deck? i don't care for rf stuff so i don't know about there amps. but from what your saying it should work the way you want just fine.
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
new deck (thinking 80 prs, or flip out)
2DIN Pioneer AVH-X3700BHS
why?
for the mids is right on.. are you getting components or pa speakers. what tweeters are you planning on getting?
by your post im assuming you want to to active. do you know how to set crossover points and setting EQ? if not youre better off getting components and using the crossover. you can get a 2 chan amp and run all on the same amp if you use the crossovers if youre planning on only running just 2 6'5
6,5s: http://store.crescendoaudio.com/neo-forte-nf6-6-5-premium-neodymium-loudspeaker/
tweeters:http://store.crescendoaudio.com/ft1-black-series/
crossover:http://store.crescendoaudio.com/ft1-tweeter-crossover/
on the crossovers, will i need one per tweeter?, or can i use one per 2 tweeters since i'm wiring in pararell?
  • Who's Online   0 Members, 0 Anonymous, 2139 Guests (See full list)
