Box pros! help 2 DSS Etho 12"s enclosure.
JMac91
Need help for a design of a box for a trunk, sealed from trunk, facing the cab seats down. Please 14" tall tops. The opening is 31" wide and side to side in the trunk is.. atleast 40".. can fit it depth wise and spin, wider is fine so I have less work sealing.. :D
Havent done aeros, but willing to try them
All I have to power 2 of these for now is an aq2200d, so a box for that would be nice, I probably wont get more power for a while, h/o alt comes first.
Because of my power im finding it difficult to decide and properly tune this thing when it comes to aeros.. Guessing game. heres specs
Re 3 ohms Le 2.94 mH Qms 5.91 Qes .54 Qts .49 Fs 28.24 hz Mms 326.15g Cms .1 mm/n BL 21.43 t/m Vas 33.1 l SPL 84.99 1w/1m Xmax 32.5 mm Power 1,800 Watts
NOTE: All parameters were extrapolated via a Klippel analyzer using LPM and LSI measurements. The recommended power rating is not a max input power rating. It is the necessary power needed to drive the subwoofer to 32.5mm xmax in a ported enclosure 1.5 cubic feet tuned to 32 hertz. This rating will vary depending on enclosure size and tuning
ALSO: Prefer port(s) to be in the mid if thats not an issue.
Vehicle: 2002 Volvo S60 2.4t awd.
Headunit: Kenwood DDX-470
Doors: 4x Focal 6.5s/tweets (Adding)
Sub: 2x Sundown Zv4 12's D1
Amps: B2 Zero.1, MB Quart OA600.4
Box: 5.2ish @ 32, Made with Maple, solid oak braces, 45s all around, 2x 5.8" pipes, all fiberglassed up.
Battery: XS D3100, Block Shakers 110AH
Alternator: 250A Excessive Amperage.
All Sky High OFC Wiring.
My Build, plenty of pics: http://www.stevemeadedesigns.com/board/topic/198281-2002-volvo-s60-awd-24t-build-log/
  • Who's Online   0 Members, 0 Anonymous, 9371 Guests (See full list)
