Set screw concern
So I have a KnuKonceptz ANL fuse holder that uses set screw connections. I want to use it for my fuse between my battery and amps. I am worried the set screw connections not being good. I have zero to 4 gauge reducers but they do not seem not seem to help. I thought about getting zero gauge inputs but not sure. My other option is buying a ring terminal fuse holder instead? What is the best way to get a good connection with a zero gauge fuse holder???
I use the ring terminals ones. I have a kicker 0 gauge fuse block I used for awhile that used the set screws and I never had an problems with the wire coming loose or anything. But if it makes you feel better (safer) use the ) gauge inputs then it definitely be hard to work loose. But if you go that route lmk I got a extra pair or tool maker inputs you can have.
Whoa awesome! You think those toolmaker inputs would work?
The ring terminal ones are usually plastic with the two metal studs sticking up, were as the set screws they gotta machine the hole and and stuff, would be my guess. I think the inputs would work there but honestly you should be fine just using the set screws, js.
But if you want the input adapters lmk
You selling them?
no they are free.
Oh really? I will definitely take them if you do not want them man! Thanks :)
  • Who's Online   0 Members, 0 Anonymous, 3140 Guests (See full list)
