battery light flashing
hello have a question for you guys with ho alternator just installed dual alternators with voltage regulators set at 14.8. After install battery light flashes tho alts are charging fine,any ideas how to get light to stop flashing?(light s driving me nuts) Vehicle is 2000 suburban, thanks in advance
try unhooking your negative battery terminal then hooking it back up. itll reset all your radio stations if that isnt a big hassle for you but that usually works for me when i have lights turn on for no reason then they go back off. it might just be a minor glitch.
2013 Ford Focus Hatchback SE
Kicker CS61234
Kicker 40CS674
Kicker KST25
Sundown Audio SA-12 D2
Rockford Fosgate t1000-1bdcp
Rockford Fosgate t400-4
Audio Control LC7i
Kinetik HC2000
0/1 Gauge
Big 3 Upgrade
Beer, babes, and bass.
I also have a GM vehicle around that age, and i also have dual alts. I get a flicker of the battery light once in a blue moon. I haven't really narrowed down the source of the problem, but I haven't gotten it since i have been experimenting with various belt length vs idler pulley diameters. if you're under the hood, do you hear any belt slippage? Does the tensioner move a lot?
Cables and wires almost never fail; the terminations do.
  • Who's Online   0 Members, 0 Anonymous, 3537 Guests (See full list)
