SHCA 0awg mounting questiom
Ok so I just purchased some 0awg from SHCA, I will be using it to add a second battery which will be located in the bed of my truck, my question is, what's the best way to secure it to the frame and protect it from the elements?
some looming and a battery water proof case...
How would I mount it thought? I seen some frame clips online but I'm not sure if it'll fit, I was also looking at metal zip ties summit racing sells
http://www.summitracing.com/parts/sum-350128/overview/
http://www.grote.com/products/99460-5-trailer-wiring-frame-clip-10-pack-retail-pack/
Would those work? I kinda want to go the first option only because I'm pretty sure they'll fit around the frame
Any time I run wire to the back of my truck I either loom it and zip tie it to existing wires, or I electrical tape it (together) twice, and seal the ends the best I can (so water doesn't get between, you'll need to split the wires at the end and tape them individually)
  • Who's Online   0 Members, 0 Anonymous, 4212 Guests (See full list)
