RT5POINT9 Posted December 26, 2014 Report Posted December 26, 2014 (This test is done using my own variable, non-reactive, purely resistive load bank ("The Amp Lab") along with an SMD AMM-1, and an SMD DD-1 for tuning. I am using AD-1 40Hz test tracks for all tests. Power is comprised of 3 AGM 12V batteries along with a 40A power supply. Certified tests are performed by tuning the amp with the DD-1 so that when the test track is run it will stop at the point JUST before distortion. Un-certified and Dynamic runs are performed by tuning the amp using the DD-1 for a -10Db overlap. This will run the amp past the point of distortion, but the AMM-1 will stop the test at the point of clipping.) Kicker KX1200.1 - Rated at 1200W RMS @ 1-ohm. Really wish I had the ability to run this at lower than 1-ohm, but my equipment at the moment will only allow down to 1-ohm.
ZAPCO209 Posted December 26, 2014 Report Posted December 26, 2014 I was expecting more from it. THE DRIVING FORCE
soundstream15 Posted December 26, 2014 Report Posted December 26, 2014 I expected rated or a bit more
