Sundown X-15s D4 -Ported box help
Helllo
Im new to the forum and hopefully someone can help me out on this
Long story short
I bought 2 brand new subs and good wires and paid for a custom box.. etc..
and I dont feel its as loud
Before this I had 2 L7s wired down to 1 ohm in a 6 cube box tuned to 32hz and it seem almost the same..(in a car)
I have
1996 2 door tahoe
2 Sundown X-15s D4 wired to 1 ohm
on a Sundown 2500.1
Clarion Eq
Kenwood kvt 512 indash
and Knuconcepts 0/4 Gauge OFC wire
I grounded the ground to the bolt of the back seats(sanded it and cleaned the area)under 12" 0 gauge
I have 1 yellow optima and a stock alternator( 0 gauge wire from alt to battery & bat ground to chassis.. Yes im missing one more for the big 3 but I dont know where )
im guessing the box is too small? port to small? or my weak alternator?
Message_1415825447204254copy.jpg[/url]
The height from top to bottom counting the tripple baffle is 17"
I tried to give all the details so someone can help me out on this :pardon::pardon::pardon:
Edited by EdgarC6789
It seems you have a lot of air space and port. 4.4 cubes per sub and 100 inches of port is definitely on the higher side of what I've seen X-15's in. Where maybe the more educated posters might be able to help out is with two ports I would assume the tuning stays the same but the port area doubles which would leave you with a tune of 23 Hz which I'm sure everyone would agree is very low.
I've got a single X-15 D2 on a sundown 2500 in a box (3.5ish net cubes with about 60 inches of port) that is close to the specs that sundown suggests and it works pretty good for a single sub in a crew cab truck.
As far as the electrical, the one step you're missing from the big 3 is a ground wire from the alternator case to the ground point on the chassis. A bigger alternator would certainly be useful, I can't imagine that you have more than a 100 amps left for the stereo with the stock alt and a 2500 should need a lot more than that. My 2500 has no problem taking everything my stock 150 alt has and still pull 2 - 35 series agm batteries down into the low 10 volt range temporarily.
Hopefully people will start responding soon. It seems some posts take off here and some don't.
EDIT - Forgot that this was posted in the sundown forum. You might want to copy paste your original post into a new post in the subwoofer and enclosure section. You'll probably have much larger audience over there to answer questions.
Edited by Titan Audio
  • 1 month later...
  • Who's Online   2 Members, 0 Anonymous, 779 Guests (See full list)
