air escaping
Hey guys I had a custom box made for my 2 15s and there is air escaping. I believe its coming from the hole the sub sits in. Besides just taking it to the guy who made the box is there anything i can do to fix it? Thanks guys really need help
1. Go to Home Depot (or equivelant) and buy some duct seal like this: http://www.homedepot.com/p/Gardner-Bender-Duct-Seal-Compound-Plug-DS-110/100212441
2. Roll duct seal into 1/8" - 1/4" diameter "worm"
3. Remove subs and put worms around bottom side of sub mounting flange
4. Put subs back into box and tighten the mounting bolts/screws snuggly
Builds:
X2
Did this for a friend just last week worked quite nicely
Depending on how you did it, the silicone should have got the job done. I prefer duct seal over silicone since it makes the sub easier to remove and the vapors coming off the silicone as it cures can damage surrounds, but they both are very effective.
If possible you might want to take a picture of your box with the sub in and out of it so we can more clearly see whats going on. I suspect you may need to take it back to the builder, but I can't say for sure w/o seeing it.
As far as the builder goes, unless there is a problem with the sealing surface of the sub, there really is not excuse for it to leak.
Builds:
@Triticum Agricolam well I believe I did it basically how your telling me to put the duck seal put it right around the hole where the screw's are but I did notice when I took the sub's out that the inner part of the hole its not level and smooth but the sub's fit great I can take pics to show you but it will be tomorrow
Sounds good, I'm in no hurry. Just post pics when you get a chance!
Builds:
  • Who's Online   0 Members, 0 Anonymous, 4784 Guests (See full list)
