12volt 7 color led kit?? Please help.
Amp output is ac voltage so that's a no go
That's what I thought, but how does this work then??
This is the controller that is used in the top link, assuming you are going to be using your own led strips instead of the overpriced ones on that website.
http://www.ebay.com/itm/12V-Sound-Active-Module-For-Car-LED-Bulbs-LED-Strip-w-Adjustable-Sensitivity-/130680412220
Edit: forgot you wanted more than one color. This won't work.
I've gotten a blowjob and picked up my iphone behind her back to see what email notification I got from smd before
that is the best one, you don't have to wire anything major...if you really want to wire it the hard way you have to get the parts to do it and the schematics on how to wire it...I would go the easy way....
http://www.eeweb.com/electronics-forum/looking-to-make-leds-pulse-to-bass-in-my-car
Seems to me that this is a budget way of getting leDs in your car.. and I'm sure it is useless with a 7 color strip.
Yeah, it looks kinda sketch
Yes I am planning a full 7+ color setup with some RGB 5050 SMD LEDs I already have.
I find it odd that I can't seem to find a controller that actually uses a signal instead of a microphone... I have a cheap LED kit that beats to sound.. and it's alitte off.... Here is the controller I'm looking at currently
HitLights Luma10 Series - Multicolor Music Controller with Remote - For LED Light Strips https://www.amazon.com/dp/B007RGRJ36/ref=cm_sw_r_awd_UOhWub058XBSR
Do they not make any you could plug an RCA into? I feel like that would be the best way to make one.
https://www.kickstarter.com/projects/1649103139/seven-channel-graphic-equalizer-breakout-board-for
This is what you are looking for and seems to be the only example of its kind I can find. Which is a shame since the funding period is over..
I agree.. if you could get one to run off a Rca all you would have to do is use the signal out on your amplifier.. an Walla
  • Who's Online   0 Members, 0 Anonymous, 981 Guests (See full list)
