Do-LowHrzHurts Posted February 4, 2015 Report Posted February 4, 2015 Need recomendation on Battery and the deciding factor would be will the D4900 fit in factory battery tray and is it worth investing the extra for my main battery up front so I have enough reserve for my system until I'm able to afford a rear battery bank? http://www.sonicelectronix.com/item_66623_XS-Power-D4800.html http://www.sonicelectronix.com/item_66603_XS-Power-D4900.html Current build 300amp alt (1) xs power d4800 up front (1) Optima yellow top 34 out back All 1/0 skyhigh car audio power and ground including big 3/4 (2) Hyphonics 2000.4 front doors 5.25" memphis mclass comps don't recall exact model# future plans to run (2) pair 6-8" mids each front door. rear ski port 6.75" Alpine Type X pro series running passive rear doors factory 5.25" need better speakers. (1) ? sub amp maybe sundown saz-4500d (1) ? Subwoofer maybe team 15" getting by with a db drive 2400.1 class ab amp thats doing a good 660ish watts rms to single JL audio 13w6v2 @ 2ohms box 2.86 cubes slot port 32hrz def need way more batteries. https://instagram.com/p/4w51kBrX9g/?taken-by=boost_syndicate
Do-LowHrzHurts Posted February 4, 2015 Author Report Posted February 4, 2015 Well got home today and measured out battery tray and D4900 a bit too big so Just ordered D4800 Now to look for 1/0 or maybe 2/0 for front to rear run. How many out there would run a positive and a negative front to rear? Gonna do 1 amp like a ctsounds 2200 or 2500 and my 4 channel 60 amps so right at 280-310 amp rating. Mechman 370amp alt should run system well and maybe do one or two batteries in trunk. Current build 300amp alt (1) xs power d4800 up front (1) Optima yellow top 34 out back All 1/0 skyhigh car audio power and ground including big 3/4 (2) Hyphonics 2000.4 front doors 5.25" memphis mclass comps don't recall exact model# future plans to run (2) pair 6-8" mids each front door. rear ski port 6.75" Alpine Type X pro series running passive rear doors factory 5.25" need better speakers. (1) ? sub amp maybe sundown saz-4500d (1) ? Subwoofer maybe team 15" getting by with a db drive 2400.1 class ab amp thats doing a good 660ish watts rms to single JL audio 13w6v2 @ 2ohms box 2.86 cubes slot port 32hrz def need way more batteries. https://instagram.com/p/4w51kBrX9g/?taken-by=boost_syndicate
