Ruben0987 Posted February 7, 2015 Report Share Posted February 7, 2015 I'm not even sure where to begin I bought a new amp for my subs for ($82)!! Audiopipe 30001d and it was all still in the plastic my Kicker vx are rated at 750rms 1500w Peak should I wire them at 1-4 Ohm because 1 Ohm will blow my subwoofer if I should wire them at 4ohms can someone please explain how to wire it and connect it to this amp that has to connections cause it 2-1500 straped Thanks I'm kinda a noob at this stuff as you can see Link to comment Share on other sites More sharing options...
islandpride684 Posted February 8, 2015 Report Share Posted February 8, 2015 Dual 2 or 4 ohm subs? Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410 Link to comment Share on other sites More sharing options...
Ruben0987 Posted February 8, 2015 Author Report Share Posted February 8, 2015 I have 2 dual 4ohm subs Link to comment Share on other sites More sharing options...
islandpride684 Posted February 8, 2015 Report Share Posted February 8, 2015 I have 2 dual 4ohm subs Wire each sub in series, then wire both subs in parallel to give you a final load of 4 ohms...the sub will see about 900 a piece...(doubt that amp will tho) and make sure you set your gains properly.... http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=42#results Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410 Link to comment Share on other sites More sharing options...
Ruben0987 Posted February 8, 2015 Author Report Share Posted February 8, 2015 But once I wire them both to 4ohm won't I just have the positive and negative Look my amp has 2 positive and negative spots What do I do im still confused http://i1.r24.me/B0VwOqnbw0WJ.jpg Link to comment Share on other sites More sharing options...
