Guest Brett32324 Posted November 27, 2006 Report Posted November 27, 2006 my twelves drained my battery. got a jump tho n its startin normally now. think i should get a yellow top and a heavy duty altinator?. im thinkin so countin on im hookin up another 12"
dmanson Posted November 28, 2006 Report Posted November 28, 2006 a nice alternator and good battery along with the big 3 will aways help the draining. 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
mtxcivic07 Posted November 28, 2006 Report Posted November 28, 2006 yeah do the big 3 with all 1/0 gauge wiring.. pick up a yellow top and pick up an alternator and you will be straight.. what kindo of equipment are you running? 18's in a wall to come....Its not all about the posts....check the member #...
dmanson Posted November 28, 2006 Report Posted November 28, 2006 yeh and how does some 12s drain your battery? you meant to say the amps drained the battery. 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
