eaglescorpio1 Posted April 9, 2008 Author Report Posted April 9, 2008 update. The width would be 36" not 34". The subs wont fit onto the box with the other dimensions if I go 34" width. And the reason that there are two heights is because the box is not square. It looks like 2 wedges side by side so to speak. The bigger height is from the floor to the top of the box, the shorter height is from the floor to where the box has to ange in to fit into the trunk when the seats are down. And the total internal volume would be 5.86 cubes with no divider before speaker and vent displacement. Thank you so much for help, and I will keep reading responses and communicating. Thank you all so much again. Any help is appreciated!!!! Quote Loud as f*ck, and sounds good doing it. Team built from here on out!!!! BIG things to come......... Missing link is the shite!!!
eaglescorpio1 Posted April 9, 2008 Author Report Posted April 9, 2008 if you go onto rockfordfosgate.com and go to box wizard it is the wedge 2 box basically side by side with the subs mounted on the flat surface, not the angles surface. Like a stop sign with the bottom angles cut off. Like a half stop sign. Quote Loud as f*ck, and sounds good doing it. Team built from here on out!!!! BIG things to come......... Missing link is the shite!!!
