Gil Loyola Posted March 20, 2015 Report Posted March 20, 2015 Alright u guys i was running my nendo 5500 at 1 ohm for about 2 months or so everything good then. I have a mechman 320 amp alt optima under hood and 2 kinetic 2400 in the trunck. 2 days ago i bough 2 tantric hdd 12" dual 2 ohm and now runing at .5 ohms. Now when i run full tilt my radiator fan will turn of and car over heats its only when running full tilt. Voltage drop to 12.5v. What other electrical upgrades do i need..... i have dual 0 gauge runs of wire to the back batts. and 4 ground 4 powers going into the amp. Any help will be apretiated. I know i need way better electrical but what would yall recomend?
Miguels Posted March 20, 2015 Report Posted March 20, 2015 wiring it to 1 ohm even if you get more batteries your voltage will drop because you have more draw than what the alt can supply my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
Miguels Posted March 20, 2015 Report Posted March 20, 2015 you can also set the gain lower. since you are droping voltage you might be clipping the amp my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
Gil Loyola Posted March 20, 2015 Author Report Posted March 20, 2015 Oh okay i cant wire at 1 cuz the subs are dual 2
