Box for a 99 trans am for 2 SA12 sundown subs
Okay so last week and I'm not proud of this I got a pre fab box for my 99 Trans Am now it is ported and they say it is 1.5 cu each side of the box and tuned to 35hz the ports look small is there any thing I can do to mod these port or does any one have any idea on a new design I could build
1441714C-5D7B-4BAC-9C5F-89C652CE2105_zps 3B4346C9-9429-4471-B279-2477541F85F0_zps now the ports are 1.5" w x 6"d x 11.5"L and each camber are separated any input be grateful I'm not proud of this box at all by any means I just thought it might be an easy fix for the car thinking about it the more I don't like it.
Not much you can do, if you do a larger port, it will take more internal airspace. If you are experiencing severe port noise I would probably close the ports and run those sealed, you can though, do a custom box based on some of the dimensions of the prefab.
Thanks if I build a sealed box should I make it 1 chamber and how mean Cubic feet should I make it I think sundown says 1 cubic feet per sub and should I deduct or add some space for the volume of the woofer thanks for all your help all you guys rock
