dbmode2 Posted April 18, 2015 Report Posted April 18, 2015 check out this vid on youtube for this problem I already have copper wire wrapped around my RCAs outputs and grounded it from my prvious amp...its still there now, and it does not seem to be helping... Did you used a multimeter on the ground points yet for the amp? to see if the ground is in the 20's or below that
Guest Posted April 18, 2015 Report Posted April 18, 2015 check out this vid on youtube for this problem I already have copper wire wrapped around my RCAs outputs and grounded it from my prvious amp...its still there now, and it does not seem to be helping... Did you used a multimeter on the ground points yet for the amp? No. For continuity?
dbmode2 Posted April 18, 2015 Report Posted April 18, 2015 check out this vid on youtube for this problem I already have copper wire wrapped around my RCAs outputs and grounded it from my prvious amp...its still there now, and it does not seem to be helping... Did you used a multimeter on the ground points yet for the amp? No. For continuity? nope on impedence on the multimeter negative test lead to the negative post on the battery then a long jumper test lead from the positive on the multimeter to the grounding point where the amp is grounding at for this test
viper1315 Posted April 18, 2015 Report Posted April 18, 2015 Possible pinched wires maybe? That has happened to me before on pinched wires under a seat and once i moved it went away. could also be pinched rca somewhere. 2001 GMC Sierra DC Audio Build =http://www.stevemead...o-level-4-build 2001 GMC Sierra XSPower D3400 Pioneer AVHD 1400 MB Quart Component Sets Pioneer 5x4s Audiotechnix Power Wire, Speaker Wire, Sound Deadener DC Audio Level 4 10s DC Audio 3.5k Rocford Fosgate R400-4 HID 6k Slammed Truck on 20s Candy Blue.
viper1315 Posted April 18, 2015 Report Posted April 18, 2015 I recently had a isue with a amp and took it out and it stopped its also changed noises when i moved it a lot and the rca inputs were bad on it. 2001 GMC Sierra DC Audio Build =http://www.stevemead...o-level-4-build 2001 GMC Sierra XSPower D3400 Pioneer AVHD 1400 MB Quart Component Sets Pioneer 5x4s Audiotechnix Power Wire, Speaker Wire, Sound Deadener DC Audio Level 4 10s DC Audio 3.5k Rocford Fosgate R400-4 HID 6k Slammed Truck on 20s Candy Blue.
viper1315 Posted April 18, 2015 Report Posted April 18, 2015 1 2001 GMC Sierra DC Audio Build =http://www.stevemead...o-level-4-build 2001 GMC Sierra XSPower D3400 Pioneer AVHD 1400 MB Quart Component Sets Pioneer 5x4s Audiotechnix Power Wire, Speaker Wire, Sound Deadener DC Audio Level 4 10s DC Audio 3.5k Rocford Fosgate R400-4 HID 6k Slammed Truck on 20s Candy Blue.
viper1315 Posted April 18, 2015 Report Posted April 18, 2015 tripple post :/ 2001 GMC Sierra DC Audio Build =http://www.stevemead...o-level-4-build 2001 GMC Sierra XSPower D3400 Pioneer AVHD 1400 MB Quart Component Sets Pioneer 5x4s Audiotechnix Power Wire, Speaker Wire, Sound Deadener DC Audio Level 4 10s DC Audio 3.5k Rocford Fosgate R400-4 HID 6k Slammed Truck on 20s Candy Blue.
Guest Posted April 18, 2015 Report Posted April 18, 2015 check out this vid on youtube for this problem I already have copper wire wrapped around my RCAs outputs and grounded it from my prvious amp...its still there now, and it does not seem to be helping... Did you used a multimeter on the ground points yet for the amp? No. For continuity? nope on impedence on the multimeter negative test lead to the negative post on the battery then a long jumper test lead from the positive on the multimeter to the grounding point where the amp is grounding at for this test Ok, I'll check the grounds for impedence...since I have rear batt, should I also front battery neg to rear battery neg?
Guest Posted April 18, 2015 Report Posted April 18, 2015 Possible pinched wires maybe? That has happened to me before on pinched wires under a seat and once i moved it went away. could also be pinched rca somewhere. I don't think this is it, I just re-ran new RCAs and the path is pretty a clean shot to the amp aside from the few extra inches at the end.
dbmode2 Posted April 18, 2015 Report Posted April 18, 2015 check out this vid on youtube for this problem I already have copper wire wrapped around my RCAs outputs and grounded it from my prvious amp...its still there now, and it does not seem to be helping... Did you used a multimeter on the ground points yet for the amp? No. For continuity? nope on impedence on the multimeter negative test lead to the negative post on the battery then a long jumper test lead from the positive on the multimeter to the grounding point where the amp is grounding at for this test Ok, I'll check the grounds for impedence...since I have rear batt, should I also front battery neg to rear battery neg? what are the numbers when you check it?
