Just about a year ago i won SOTM and lost interest on the forum after what happened with that, long story, but I am gonna restart with a fresh build log of the wrangler again.
Lets play some catch up since the sixth order!
(2) 18" Zv4s
(1) CT Sounds 7000.1
(1) Northstar AGM 400
(1) 320A Singer Alt
Dont mind the bondo, this is the only photo i have of this build. Had the port tuned around 56hz, sealed section was a bit big, and ended up in the trash.
10338661_791187950899611_130237931221769
Next up i tried another 4th order,
10570428_817582754926797_62862828251373810384656_818651994819873_500256481388273
This one did fairly well, but still not what I was looking for....
So i sold EVERYTHING but the amp. for some x12s almost quit audio and gave the walled life up, and built this.
10346388_832922156726190_572526112349081
10612965_835904416427964_799669561493524
10428441_838672272817845_753229733842747
That was for (2) Sundown X12s running on the ct 7k at half ohm (coil smell for days) But it got the job done for about a week and it was NOT loud enough.
And that ends my short little rebuild catch up for yall! Time to show you what ive got now!
I ended up getting my 18s back after i sold them for the 12s, But not in the condition i sold them as.......
10659405_853945147957224_719824792071017
That put a damper on the rebuild, but it was for the better.
I decided on upgrading the woofers by adding direct leads and nsv3 spiders,
10402587_892992360719169_178341851625403
10885551_893074510710954_838206444899684
So next up is the design since we already have everything else!
(2) Sundown Audio Zv4 18"s (NSv3 Softparts)
Airspace: 14.5uft
Tuning: 30hz
Port Area: 168.4375sqin
10298029_891156337582370_858389516513720
Was going to stain the enclosure, but was not sure how it would turn out with pink dustcaps and a yellow jeep (bad idea to buy them dustcaps lol)
Ended up with a Castle Gate grey!
10407237_922973631054375_811156082905637
10984980_923272117691193_788449537165162
Test fit, and playing around with my decals for the dustcaps, they didnt last long i didnt care for the look.
10848810_923069231044815_794303082881435
Time to make some trim panels and pretty it up!
Ill be keeping an eye on this one for sure. I've been thinking about ditching the 4 12's in my jeep and going to 2 high quality 18's. This build log will probably be the deciding factor for me. Good work man.
2014 JKU
Sound:
pioneer xav-65
4 12in pioneer tsw3003d4
2 pioneer gm-d9601
(much more in route)
General:
18in worx rims
33in tire
stinger src bumpers
light bars
6k hids
2in leveling kit
3.25in lift
The Build Log: http://www.stevemeadedesigns.com/board/topic/195839-2014-jku-build-4-12s/
Fast forward, the roof was THROWING OFF THE VIBE!!!! white just was not looking good with the carpet.
11075155_947344618617276_526918774238338
11081372_947344638617274_165637005206368
11083599_947344578617280_999471355063472
1897856_947344605283944_9146248247300175
Just used some plastidip to give it a better look! MUCH better. should come from the factory like this!
Now heres the trim panels on the box, still need slight work but, itll do for now 11096487_952727134745691_424463910179678
Got the rear of the wall wired up, minus the two four channels in this photo.
10983426_925064220845316_526049594755617
11011031_948097941875277_286116848334549
Testing wasn't bad, build was NOT designed for numbers, kind of shocked me.
Now to get the 4 channels wired up, How many of you walled guys can do this (in under 10 minutes)
10003910_953393131345758_182131755625640
Got me some GP RCA's and a Cock Box!
10464406_960508460634225_825287968135444
994131_960515957300142_45581445816273092
Dont mind my TERRIBLE carpet job on the rear LOLOL, never thought yall would see it ;) Missing my second 4 channel in this photo but yall get the point.
11166032_961529543865450_1378224419_n.jp
gains are positioned so i can adjust them while the roof is on, incase you all were wondering.
I forgot to add, the front stage consists of 6 rockford fosgate silkdomes, 2 PRV 6.5s (The big bad neos) and the rear stage is the 8 cheap prvs 6.5s. It seems like it would be terrible sound quality and staging wise, but it actually turned out VERY good (shocked again) but its no means a sound quality setup lol
Got carried away with testing, but no big deal was due for a new one anyway 10993092_927522257266179_596479586918224
........ never mind i turned my defrosters on max, when its was like 10 degrees out... one day ill be loud enough LOL
Newest addition to the exterior is a rough country lightbar though, so this is a great before and after photo!
10407790_932617310090007_529934551294037
10672399_932895213395550_681123071287333
10339703_940461535972251_555032883649221
