conbon Posted April 28, 2015 Author Report Posted April 28, 2015 You'll be fine with that sub on that amp if the gain is set properly and the enclosure is built right. As stated earlier if something doesn't seem right turn the volume down and figure out what's up. Wire it to 4 ohm if you want to play it safe. yeah i was figuring 4 ohms would be the best option. and i dont know if youre familiar with high output enclosures but i bought my enclosure from them. 1.75 cubes and vented. its a very very well built box. sounds incredible. tuned 35 hz. 2013 Ford Focus Hatchback SE Kicker CS61234 Kicker 40CS674 Kicker KST25 Sundown Audio SA-12 D2 Rockford Fosgate t1000-1bdcp Rockford Fosgate t400-4 Audio Control LC7i Kinetik HC2000 0/1 Gauge Big 3 Upgrade Beer, babes, and bass.
Cj Kumz Posted April 28, 2015 Report Posted April 28, 2015 How much power does your amp put out at 4ohms?? 1 ohm will be best if you know what you doing. Like said above on music you won't see that much power 1.75cubes is still within the recommended so you should be fine. Going more towards 2 cubes will make the box a little more efficient and you will probably gain output frm that. But try and error will have best results Vw Polo Pioneer Deh-6050UB Sundown Saz-3500d DD Audio 9500 15'' 5.5 cubic feet box with 10 inch port @ 38hz I live to hear the Bass drop!!!
conbon Posted April 28, 2015 Author Report Posted April 28, 2015 How much power does your amp put out at 4ohms?? 1 ohm will be best if you know what you doing. Like said above on music you won't see that much power 1.75cubes is still within the recommended so you should be fine. Going more towards 2 cubes will make the box a little more efficient and you will probably gain output frm that. But try and error will have best results birthsheet says almost 900 rms. but at 1 ohm do you think my electrical will be okay with a kinetik hc2000 12v, big 3, and stock 150 amp alt. and ill also be running a rockford t400-4 for mids/highs 2013 Ford Focus Hatchback SE Kicker CS61234 Kicker 40CS674 Kicker KST25 Sundown Audio SA-12 D2 Rockford Fosgate t1000-1bdcp Rockford Fosgate t400-4 Audio Control LC7i Kinetik HC2000 0/1 Gauge Big 3 Upgrade Beer, babes, and bass.
Cj Kumz Posted April 29, 2015 Report Posted April 29, 2015 That's quite a big stock alt you gat there. Get another battery for the back and you should be fine. Or best thing would be to get a voltmeter and monitor how bad you voltage drop is before getting the battery. Vw Polo Pioneer Deh-6050UB Sundown Saz-3500d DD Audio 9500 15'' 5.5 cubic feet box with 10 inch port @ 38hz I live to hear the Bass drop!!!
conbon Posted April 29, 2015 Author Report Posted April 29, 2015 That's quite a big stock alt you gat there. Get another battery for the back and you should be fine. Or best thing would be to get a voltmeter and monitor how bad you voltage drop is before getting the battery. i know but i do have a 2013 vehicle so thats a main reason why its so big. and i will be getting an extra battery no matter what and big 3. 2013 Ford Focus Hatchback SE Kicker CS61234 Kicker 40CS674 Kicker KST25 Sundown Audio SA-12 D2 Rockford Fosgate t1000-1bdcp Rockford Fosgate t400-4 Audio Control LC7i Kinetik HC2000 0/1 Gauge Big 3 Upgrade Beer, babes, and bass.
