System cuts in and out at high volumes
Grounding, input power voltage, or input signal voltage. Check input voltage like I said, if that's good, unplug RCA's from amp and attach positive lead to center pin on your RCA's and ground lead on a bare metal ground and measure AC voltage as you turn it up to the point where it usually cuts out at. Most amps can only intake up to 5VAC.
Will do. Thanks.
Vehicle: 2013 Ford F-150 STX SuperCab 5.0L V8 4x4
BIG 3: Knukonceptz Kolossus Fleks 0 Gauge OFC Power Amp Kit
Headunit: Stock (Leaving factory look)
Speakers: Stock
Subwoofer: Incriminator Audio Lethal Injection 10" D2 wired down to 1 ohm
Enclosure: ~1.5 cubic feet tuned to ~34 Hz (Port Area ~24 inches)
Amplifier(s): Sundown Audio SAE1000.1D
Amp Power Kit: Knukonceptz Complete 4 Gauge OFC Amplifier Installation Kit
