brentpadgett Posted May 10, 2015 Report Posted May 10, 2015 New here so please bare with me! Trying to do the Big 3 upgrade and so far I have replaced the factory ground wire with Sky High 4ga wire with the 4ga lugs, solder method! I also grounded the battery to the chassis since the battery was only had one 8ga ground to the block. With all that said I am still running with stock with from alt to fuse box under hood then looks like fuse box to battery, hope you are still with me on this! My question is do I disconnect wire from alt and fuse box and run wire from alt to battery with a 300amp fuse? Any help would be great and I will add pic to show what I am currently running. Thanks
whack0922 Posted May 11, 2015 Report Posted May 11, 2015 All I did was I just went from alternator positive straight to the battery positive with fuse. Alternator bolt - ground battery negative - ground alternator positive - fuse - battery positive That's what mine looks like ^
brentpadgett Posted May 11, 2015 Author Report Posted May 11, 2015 Would you have a pic of the fuse box and wiring?
Rich Schenk Posted May 11, 2015 Report Posted May 11, 2015 If your car dgrind have a frame and is a uni body ground to shock tower it's a much better ground then the one in the pics. Also ground everything to the same point vs multiple points. Keep oem wires where they our do not get rid of them. Also after u grind down to bare metal put dielectric grease On all connections. Also ground your alt to battery. On 3/28/2014 at 4:22 PM, KyLar96 said: Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science... Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/ 2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/ 2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
