Can you get the bumper off or get behind to put some foam/thick rubber between the bumper and brackets.
Nav-TV Zen V Audio Interface
AudioControl DM-608
(2) Stevens Audio Neo-Comp Full-Size Horns
(4) Faital Pro 6PR160 6.5"
AudioControl LC-6.1200
(1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz
Ampere Audio AA3800.1
Odyssey ODP-AGM48 Battery (Starting)
Odyssey ODX-AGM31 Battery (Trunk)
Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs
I've put pieces of rubber and stuff between the bumper and brackets but they just fall out I can get behind it to spray expanding foam but I want it to be the stuff that doesn't dry hard im afraid if I put to much in there it will make my bumper bulge out
I have a 09 impala, For some reason I have a lot of rattles to and I use deadner on the trunk. Let me know what u use. I was thinking of using the foam.
I'll let you know what I decide im gunna grab some stuff tonight maybe and try and do it tomorrow
Could you share the necessary steps for removing the front door trim panels? A friend of mine has a '12 Impala and wants to install new door speakers. Thanks.
Ok I got my deadener installed in the doors I took a few pics of the bolts you need to get to to take the door panel off
You have to pop the red peice of and there is a 7 mm screw behind it
CDDE94C0-437F-42F1-8245-B818BAD208A3_zps
21002CA3-868F-4FC0-9543-5D20E0475C03_zps
There's 2 10 mm bolts you have to remove here there under the rubber piece
254C8FBE-11B1-4044-90D8-E521DE51C7CF_zps
Then you Pop this plastic piece off and there is a torx screw behind it not sure what size I used a flat head screw driver to take it out
40B6FDBB-2179-4D05-A805-428DA3ED521C_zps
C8A46855-9257-4B8B-984A-D1140351F30A_zps
You also have to take this triangle piece off it just pops off
6FD040EA-E976-48B6-AB3B-C8E1BD422D0E_zps
Once you get that off just pry around the edge of the door with a screw driver and it will pop off there is a plug you have to unplug and you have to pop the cable from the door handle out its pretty easy just push one tab through the hole then use a screw driver to push the other tab and it will come right out
Thanks for taking the pix JT. They'll come in real handy when my buddy gets his new speakers.
2011 Chevy Silverado LT 5.3L 4x4 Ext.-cab
"Enjoy yourself. It's later than you think."
  • Who's Online   1 Member, 0 Anonymous, 3565 Guests (See full list)
