Can someone make me a custom enclosure design?
guttagfx
looks good..
ill need 3 more measurements. the horrizontal length of each of ur angles (measures along the same path as the bottom). and the height of ur lower horrizontal section.
once i get these, ill get to work on ur console design. ill have it to you in the am
2014 Ford Focus SE Sedan
Factory Sony 10 Speaker Sound System
1994 Ford Bronco
Dual head unit (i kno)
Sony door speakers
Kenwood Rear Speakers
Custom Center console in the works. will house an NVX NSW10"
https://m.facebook.com/WinnsCustomCarAudio/
thats what i needed.. working on it now.. ill have ur design and cut list for u in the am..
1994 Ford Bronco
Sony door speakers
Thanks i really do appreciate it. To this day i dont really understand how making a box to a certain specs(tune) can affect the way a sub performs, is it because of air space?
it can be a number of different factors. I use WinISD (free program) to design boxes. the program shows me the response curve of the woofer, port velocity, and many more things thatll help dial in how you want the woofer to perform..
1994 Ford Bronco
Sony door speakers
Ok, what do you think about that sub and amp they recommended me on here by SoundQubed
Foe the width you have (11 inches). You can't fit a 12. But can fit a 10.. I'm almost done designing ur box based around the hds310
1994 Ford Bronco
Sony door speakers
ok.. so took some tinkering.. but I was able to keep the size you listed.. again this design is for a 10 inch woofer (Soundqubed HDS310).
I made it with woofer and port facing back (most efficient way)
Use this image to cut ur side panels..
This image shows how ur panels will be put together with all the different angles
1994 Ford Bronco
Sony door speakers
  • Who's Online   0 Members, 0 Anonymous, 3292 Guests (See full list)
