I need help with a box design
SIRSOCAL
1 it is then.
Do you know how much, the gain setting device is?
Pioneer avn p4004 dvd for now
Jl e4300 replaced
Polk audio 4000.4 high & mids for now
Titanium 2000.1 subs amp for now
Crescendo BC2000D on the way 9/11 home at last
Infinity kappa 52.71
Infinity 3032cf
2 Memphis c3 15 d4
If you mean a dd1 ( distortion detector) it's in the 150 range..
Here is a good video to match gain for an amp that is too powerful
https://youtu.be/gg2gl-fz2Qc
2014 Ford Focus SE Sedan
Factory Sony 10 Speaker Sound System
1994 Ford Bronco
Dual head unit (i kno)
Sony door speakers
Kenwood Rear Speakers
Custom Center console in the works. will house an NVX NSW10"
https://m.facebook.com/WinnsCustomCarAudio/
I just check out the video, all this time I never knew that. Appreciate the info.
Jl e4300 replaced
Infinity 3032cf
2 Memphis c3 15 d4
LIks great man, I appreciate your time.
Is the port, what is referred to as an L port? and with the port being in that location, I think I Saw something about that making the driver seat the Loudest point in the vehicle or something of that nature? Is mdf still the choice, for this, 3/4?
Jl e4300 replaced
Infinity 3032cf
2 Memphis c3 15 d4
It is an L port yes.. L is very short b/c you need only 24 inches of effective port length and the depth of the box is 22.. so your port pices you will need to cut are..
Port
15.75x 14.5
15.75x 2.25
Top X2
22x50
Bottom
22x 50
Front
15.75x 42.5
Back
15.75x 48.5
Sides
15.75x 22
And port position is up to you. If you are able to build another box with port on opposite side for testing you can. I personally like my ports on passenger side.
And yes 3/4 MDF.. top of box is 2 layers
1994 Ford Bronco
Sony door speakers
well have been looking at this all day looks like I'm going to need two sheets of MDF? Home Depot and Lowes has the same price for the 4 by 8 sheets in my area do you prefer one place over the other. what materials do you recommend GluE carpenter screws caulking?
how far should the sub closest to the port be away from The port? and how far should the other sub from edge of the box?basically the Subs spacing?
Jl e4300 replaced
Infinity 3032cf
2 Memphis c3 15 d4
either place.. its the same stuff.. lol..
use titebond wood clue, 1.5" COURSE thread dyrwall screws (drill and countersink for every screw location), silicone to seal all inside edges, body or wood filler for screw holes and any imperfections.
after you cut your top. measure from edge (opposite port) 21.625 inches. measure from same edge and mark at 43.25 inches.. then draw vertical lines at those marks. then draw a line from each corner where u marked accross at a 45 degree to get your center for ur subs..
i hope that made sense.. basically you want 2 X's to show center for sub..
1994 Ford Bronco
Sony door speakers
  • Who's Online   1 Member, 0 Anonymous, 1288 Guests (See full list)
