3.0-3.5 cubes enough for 2 10s?
TITLE STATES 2 TENS BUT I MEANT 3.
Is 3.0-3.5 enough space to run 3 10s efficently? Im talkin 3 cubes after displacement at 33-35hz. I know i didnt have enough space for 2 12's but if i can fit 3.5 or even 3.2 NET would be enough for say 3 hdc3 10's or tantric md, etc
What's your dimensions? How much power are you going to run?
Your port is going to take a pretty big bite out of what space you have available.
Builds:
15H 22D and 38W Its almost 6 cubes i believe, but after displacement and subs its 3.5 which i know is slightly small for 2 12's
Gonna be running off AB vfl 175.1
Those box specs are a little smaller than ideal but I think you should be fine with HDC310s.
Builds:
Really? Well i dont want it to be too small. I had 2 12s in 1.3 cu ft each ported. Would i be better off with 2 10s with 1.75 cubes each? Just trying to get louder than my 2 12s since they were in a small box.
Three HDC310s will be louder than two in 3.56, though it will be somewhat dependant on what impedance load you will be wiring at. The three will have smoother frequency response and will be able to handle more total power.
Builds:
Gonna wire them to either 1 ohm or .5 ohms.
How are you going to wire three subs to 1 or .5 ohms?
Builds:
  • Who's Online   0 Members, 0 Anonymous, 3192 Guests (See full list)
