CrazyCricket12 Posted August 2, 2015 Report Posted August 2, 2015 I've tried searching with not much luck so forgive me if this has already been covered. I have a 125a alt on my vehicle. There is no aftermarket replacement h/o alt so my question is. Can I just add enough extra batteries to run a 1200-1500watt amp along with a 80-100watt 4ch? Thanks.
DrewJones Posted August 2, 2015 Report Posted August 2, 2015 If you truly can't find anything to replace it, then yes. You can make it work.A nice starting battery, with a decent rear battery should cover you well.After doing Big 3/4/5 lol Make it as efficient as possible. Edit: What do you drive? TEAM SOUTH Bassahaulic Productions The ONLY Bright Atlantic Blue DiamondBoxx L Drew Jones Bassahaulic Productions 4 SSA ZCON 15"s 2 Sundown SCV-6000's 6 AGM G31's 161.6 @ 40Hz Outlaw 159.8 @ 36Hz Legal ┌∩┐(◣_◢)┌∩┐
CrazyCricket12 Posted August 2, 2015 Author Report Posted August 2, 2015 2015 Mazda 3. From the stock battery measurements I took I should be able to fit a XS d975 in the factory battery tray. What secondary batteries would you recommend?
DrewJones Posted August 2, 2015 Report Posted August 2, 2015 A second D975 or a D1200 would be plenty I'm sure.Just use nice, OFC wire. And you should be ok. TEAM SOUTH Bassahaulic Productions The ONLY Bright Atlantic Blue DiamondBoxx L Drew Jones Bassahaulic Productions 4 SSA ZCON 15"s 2 Sundown SCV-6000's 6 AGM G31's 161.6 @ 40Hz Outlaw 159.8 @ 36Hz Legal ┌∩┐(◣_◢)┌∩┐
CrazyCricket12 Posted August 2, 2015 Author Report Posted August 2, 2015 Awesome. Thanks for the help.
