tino-sdf Posted August 5, 2015 Report Posted August 5, 2015 Hello, sry for my poor english ! I need help about my enclosure for my Sundown x-8 Enclosure Specs: internal volume without por and driver: 1.558 ft³ internal volume - port and driver subtracted: 0.851 ft³ Portarea: 15.066 in² Portlength: 42.7 in² tuned 32 Hz my local dealer said i shoud use only 0.529 ft³ internal volume, port and driver subtracted. The X-8 D2 should be wired on a Pioneer SPL2000PRS 2KW at 1Ohm Does my calculate work, or it works better with the smaler volume? Look at my build:
khinds94 Posted August 5, 2015 Report Posted August 5, 2015 Keep that volume... With impedance curve and that amp the .3 cubes of efficiency will only help you. 03 Sable LS AA mayhem 12" D2 Sundown ZV4 12" D1 Tantric HD 12" D2 Tantric SHD 12" D1 Sundown X12 V2 D2 2.5 cu net Sundown 2000d @ 1 ohm XS Power XP2000 Sky High Sound Deadener Sky High wire Stock alt
tino-sdf Posted August 5, 2015 Author Report Posted August 5, 2015 Thx for reply. My english not good, sry i don´t understand you right. Wich volume you mean? My 0.85 ft³ or the 0.53 ft³
khinds94 Posted August 5, 2015 Report Posted August 5, 2015 Keep the .85 03 Sable LS AA mayhem 12" D2 Sundown ZV4 12" D1 Tantric HD 12" D2 Tantric SHD 12" D1 Sundown X12 V2 D2 2.5 cu net Sundown 2000d @ 1 ohm XS Power XP2000 Sky High Sound Deadener Sky High wire Stock alt
