Noflex Posted August 10, 2015 Report Posted August 10, 2015 I'm running 2 hifonics 1861 amps both wired down to 1ohm load each have 2 powerrbass L-15s on them everything is wired exactly the same does anybody know why one amp would be pushing more power then the other at about 1/4 volume one amp will read over 3 volts and the second will read just over 1 volt thanks
yurvalentine Posted August 10, 2015 Report Posted August 10, 2015 One amp reads 3v and the other 1v? Where and what are you measuring the voltage of??
Noflex Posted August 10, 2015 Author Report Posted August 10, 2015 Sorry for the gain when I hooked up multimeter to set my gain it would have Ben ac for the outputs on the amps one amp puts out a lot more power then the other an both are set up exactly the same
Noflex Posted September 21, 2015 Author Report Posted September 21, 2015 It's pretty good seems to do its job doesn't over heat I have double 1/0 wires to it so it gets plenty of power
