mike-g Posted August 29, 2015 Report Posted August 29, 2015 so i need help with a ported enclosure design for a eclipse sw9122 12.i found a few sites online that say less than 1cuft 40hz.that seems way to small from the things ive seen about the 3hp motor 300+oz, and 2-3inchs of cone travel.i cant seem to find t/s parameters or box specs that seem right.any help would be appreciated thanks
Deeznutz Posted August 29, 2015 Report Posted August 29, 2015 http://www.stevemeadedesigns.com/board/topic/137133-eclipse-titanium-sw9122-enclosure-specs/ -Frank
mike-g Posted August 29, 2015 Author Report Posted August 29, 2015 so magnet is 250oz ,vas-3.20,320?qts-.30,fs-22hz duel 4ohm 3in vc,xmax-1.5in thats all i can find right now
mike-g Posted August 29, 2015 Author Report Posted August 29, 2015 so magnet is 250oz ,vas-3.20,320?qts-.30,fs-22hz duel 4ohm 3in vc,xmax-1.5in thats all i can find right now it kept posting sorry for all the post my bad
Deeznutz Posted August 29, 2015 Report Posted August 29, 2015 You probably found this one already. It has a pic of the enclosure and sub. http://www.soundsolutionsaudio.com/forum/topic/49191-eclipse-sw9122-ported-enclosure/ -Frank
Deeznutz Posted August 29, 2015 Report Posted August 29, 2015 http://www.audiogroupforum.com/csforum/showthread.php?t=2404 -Frank
Deeznutz Posted August 29, 2015 Report Posted August 29, 2015 http://www.caraudio.com/forums/subwoofers/164032-need-specs-sw9122.html The guy that posted these specs has the SW9122 as his avatar is that helps. Fs 27.676HzVas 32.4LSd 430cm^2Qts .328Qes .351Qms 5.00Znom 8 (series)Revc 5.9 (series)Xmax 23.15mmBl 28.00TmPe 1000Wrms -Frank
