does this sound good?
dsw422
hey guys.. im building a box for 2 cerwin vega vpro 15d2's...
sub recommends 3 cuft per 15 (so 6 cuft for the 2). i decided to go with around 8 cuft total for more output..
box dimension are 62w, 18t, 18d (i think those dims are right, not at my computer now...)
port width is 8" tuned to 33hz (i think so.. lol.. i check my computer when i get home)
box will be in a 95 chevy 1500 ext cab. subs up, port up centered.
Question is...
Will the larger enclosure be ok for these woofers?? ive been told some subs like larger than recommended and some you shouldnt go over recommended..
thanks for the help..
2014 Ford Focus SE Sedan
Factory Sony 10 Speaker Sound System
1994 Ford Bronco
Dual head unit (i kno)
Sony door speakers
Kenwood Rear Speakers
Custom Center console in the works. will house an NVX NSW10"
https://m.facebook.com/WinnsCustomCarAudio/
What amp?
Builds:
currently a planet audio 1000.. but said he willbe puting rated power to em
1994 Ford Bronco
Sony door speakers
I didn't look up the specs on the subs, but one thing I'd give some thought to would be over excursion with the larger box. As you increase box size, your cone excursion goes up to. I don't know if you would have any problems with the power he will be running or not, but its something to be aware of.
Builds:
so do you recommend i tell him to put less than rated (900 rms) to each woofer or go with smaller box
1994 Ford Bronco
Sony door speakers
I'd just tell him to use his brain with the volume knob. Those subs could fine totally fine on rated power in that box, or they might not. Once you go over the recommended size enclosure you just need to have a little caution, that's all.
Builds:
10-4.. thanks
1994 Ford Bronco
Sony door speakers
  • Who's Online   0 Members, 0 Anonymous, 488 Guests (See full list)
