nocturnalrites101 Posted October 18, 2015 Report Posted October 18, 2015 https://www.facebook.com/GladenAudio/photos/a.431808296862491.91730.431772700199384/961714327205216/?type=3&__mref=message_bubblehttp://gladen.com/amplifier.htmlsaw this wonder if its based off the same korean board the rest of the 5ks are? anyone have any info on this?
FourRings Posted October 18, 2015 Report Posted October 18, 2015 They are big in Europe,they're tied in with Mosconi but are German and tough to come across in the States.This is copied from a FB page I follow from the UK All new power house monoblock from Gladen Audio SPL 5000C1. Available in 2 variants "LV & HV" optimised for 12V or 14/16V power supply use. Available now Only through authorised Gladen Audio dealers. RRP £1099 - CLASS-D Mono Amplifier, 1 Ohm stable- 5000 Wrms @ 1 ohm - Linkable with 10000 Wrms @ 2 ohm- Low pass filter with 24 dB slope- Subsonic Filter- 0-180° phase shift- Bass adjust 0-12 dB from 30 Hz -90 Hz- Optional remote available @ 1 Ohm mono 1x 5000 Watt@ 2 Ohm mono 1x 2700 Watt@ 4 Ohm mono: 1x 1350 Watt Size: 654 x 235 x 52 mm Early tests show the 18V unit to surpass 7000w.
nocturnalrites101 Posted October 18, 2015 Author Report Posted October 18, 2015 oh i know who gladen is im speaking of the specific amp. if its the same board as others or its own thing. so far the consensus is its a copy
FourRings Posted October 20, 2015 Report Posted October 20, 2015 there is a pretty active forum in the UK that would probably get you the info you need.Its run by a older guy and I think is called lets talk car audio or something along those lines.If you find his vids,you'll find the forum.If I was home I could post a link for you.
