another ? about tline.
mike-g
Is that just a model of the enclosures or is it with the driver, and would it change if it was without the driver and specs for my sub
That was modeled with your particular sub, using a different sub could give very different results depending on the specs of the sub.
As far as a recommended ported box goes, 2 cf net airspace tuned to 32 Hz should work well. If you made it bigger than that you would get more output around tuning but it could become peaky, making it smaller would give smoother response, but would cost you some output.
Builds:
So I decided to go with the tline since it was laid out and I ve never heard one before.it was only 40-50$ for it all so it'll be a learning experience.
Well it should be a fun experiment for you. Let us know how it works out! I want to see pics too :-)
Builds:
10:-4 got everything built except the baffel,45's and the top its not perfet and I wanted to do a 1\2 round over every here need,but couldn't find my bit and was wanting to have it built yesterday but ran out of wood with better planning I could've gotten it done with one sheet,when I get back from home depot I'll get pics. What should I do for sealing the inside is the construction grade liquid nails good enough most of the time is do you or anyone do more to insure better sealing
  • Who's Online   0 Members, 0 Anonymous, 2985 Guests (See full list)
